Is it possible to visually get illustrated which constraint stops a dimension move?
Sometimes I try to use dimension to snag a collection of several objects which is related to eachother with other dimensions, and i get constraints errors.
Like i have 15 objects, and all linked, and i want to align it to 0 mm to a line on the left, then it gives an error, but it does not show me which constraint i need to remove or modify for my action to go through.
Is it possible to visualize this?
There isn't any one constraint that is failing - the sketch is a system of simultaneous equations that has multiple solutions and any one of the red constraints can be deleted for the sketch to be solved.
Also - hold Shift when dragging to prevent additional constraints from being accidentally added.
@bård_olsen a trick I use a lot when I have things broken and I'm not sure what's locking it up, is to select everything I need to move, and use the sketch transform tool to move it. This will break any constraints that are needed to complete the transform, while keeping the ones that are internal to the selected shapes.
