Why can i sometimes not select certain feature in my model?
wierdwierd Member Posts: 2
Hello Everyone,
Problem:
When using features like extrude, circular pattern or other features i sometimes cant select the things i wanna select.
Example:
Down below you can see im doing the learing course and i wanna use circular pattern for the small hole in the middle but i can only select the entire part.
If i click in my feature list on the left nothing happens.
However i can select everything on the "axis of pattern" menu.
Just not with "entities to pattern"
There will be and example of 2 pictures down below with some text to explain.
I struggled with this more in the past and hopefully someone can tell me what i am doing wrong.
Thanks everyone in advance!
Picture 1: Showing i can select the hole i want right now without circular pattern selected.
Picture 2: Showing when i try to mouse over the part it selects the whole part and not specific features.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,902 image
    Change from "Part pattern" to "Feature pattern"
