Center point line
One thing I find is quite time consuming is sketching a line such that the center is aligned with some other entity.
Currently, I draw a line, add a point to the center of the line then add a constraint, say vertical or horizontal, to the center point to the other entity.
A tool to do the job I imagine would be called 'center point line' and behave similar to center point rectangle.
Anybody got a better method? Could this be a feature request?
Thanks
    john_mcclaryjohn_mcclary Member, Developers Posts: 3,907 PRO
    You're doing it right. Even a center point rectangle is simply a rectangle and a point that has the constraints added for you.
    It could be a good idea for a feature request, go ahead and create one on the right.
    Flint_O_BrienFlint_O_Brien Member Posts: 2
    Yes. I have a line that is 117.85 long. I believe I have to add a point and a constrain with half that number. Then if I make the line longer, I have to edit the “center” constraint. Very awkward to specify and keep a line center.
    steve_shubinsteve_shubin Member Posts: 1,069 ✭✭✭✭
    eric_pestyeric_pesty Member Posts: 1,547 PRO
    A marginally quicker way is to use a construction line (if you are already using the line tool, use "q" to toggle construction, a regular line works too for that matter) that you can create directly from the midpoint of your line to your reference (and set it horizontal or vertical).
