Sketch Dimensions in BOM
troy_ostrandertroy_ostrander Member Posts: 26 ✭✭
Hello OS Community,
Is it possible to link sketch dimensions of a subassembly into a BOM?  See attached mockup image.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,922 image
    Only with computed part properties, which requires Pro or Enterprise.
  • EvanReeseEvanReese Member, Mentor Posts: 2,676 PRO
    If you aren't on Pro and able to use computed properties, you could use FeatureScript to hijack an existing property, like "Description" or "Title_1" with a custom feature to show them. Here's an example.
    https://cad.onshape.com/documents/4e51452ff70b3ad0eec3834a/w/4dd316799a1900ab58bc1e38/e/a4bd5d3b9ab5c1ff60232754
     Here are the basic steps:
    1. set the values as variables
    2. make a feature that calls those variables, and converts them to a readable format (i.e. rounding them, removing the units, adding other text like "Length" etc)
    3. insert the feature after the part is created and select it.
    I don't know your comfort level with programming, so I may be under-explaining it. Feel free to ask for more info where needed.
