Feature Script
Pablo_ManeroPablo_Manero Member Posts: 8 PRO
Hello!
I'm looking for any feature script which can give me back the name of the version where I'm working in.
The reason for this is the following one: I want to assign a customize part propertie where the part number contain the version name, so I need to achive the document version to add in a variable.
Thanks!
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,927 image
    Hi @Pablo_Manero - it's not possible to read the version name, but if you are using Release Management, you could read the revision and write it to a property. However, you would be adding the property to the current workspace, not the revision, so if somebody looks at the revision it will have the previous revision's value (or no value).
  • Pablo_ManeroPablo_Manero Member Posts: 8 PRO
    Hello Neil;
    Okey, thank you! I would had liked to use the version name, but I will try it with the revision number.
