Screen goes red when I add a parallel mate
sandy_scottsandy_scott Member Posts: 3 ✭✭
Hi, I'm evaluating Onshape and I've just tried importing a very basic assembly
After adding the final mate, the parallel mate. The 3d area goes solid red
This behaviour is reproducible when I try before and after that feature in the history tree.
Document
https://cad.onshape.com/documents/eba8f0e0590befebfa999130/w/856ab4d514f029f254958791/m/92feff14eefcef87d9395910/e/30ba2ee18b3a9e4610cb0a6f?renderMode=0&uiState=6344356edbbec40a987f0301
before:
after:
everything looks OK on the compatibility check screen:
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,927 image
    If you zoom out you'll see it is actually the failed tangent marker - why it is so big I don't know. Press J on the keyboard to hide. I recreated the assembly in a new tab and it was fine. Very odd - if it happens again please open a support ticket.
  • sandy_scottsandy_scott Member Posts: 3 ✭✭
    OK, that's fairly weird. Still not sure why it doesn't like that mate - if i also create it in a new tab the tangent mate works (after flipping the primary axis), but that fix doesn't work in the original assembly
  • glen_dewsburyglen_dewsbury Member Posts: 1,223 PRO
    That looked weird. Pretty sure your trying to over constrain.
