Create terrain surface from set of points
jeff_mcaffer
Member Posts: 94 ✭✭✭
in General
I have a set of points in 3d space (I'm starting with a 5x5 point grid with a "height" at each point) and would like to turn that into a surface. The use case is modelling some terraforming in my front yard. I have some particular access issues and want to see if various changes improve the situation. I saw the topographinator, very cool but I'm not sure if/how it applies here.
Alternatively, to doing it directly in onshape, is there a separate tool to create a surface and then import it from say a DXF file or some such?
Jeff
Jeff
There is something like this that creates splines that you could then loft between: https://cad.onshape.com/documents/a5566bc4a7c123d4958fd925/v/74ef42fd67330626670210c7/e/97994fc552ad661c4611715d
have you looked at https://phi3d.com/ ?
