Constraining a mostly curved sketch
jtpryjtpry Member Posts: 2
Hello,
First off, I’m quite new to Onshape, and very new to CAD in general. My experiences have really only been with tinkercad. So please excuse my ignorance if what I’m asking is basic, or I’m not using the correct terminology.
I was making a clay cutter to be 3D printed for my partner and it’s a simple ghost shape - It has a blade, wall, brim, and center pieces that indent the clay. I created all the lines within the one sketch that way I could extrude each face appropriately. My goal is to make 3 sizes that change the overall size, but I can keep the blade, wall, and brim the same size regardless of the cutter shape.
Anyway, the shape has quite a few curved spots that make up a majority of the shape, and it required a LOT of dimensions to constrain it. I’ve attached my initial sketch with required constrains. It’s a lot. You’ll notice that it’ has redundant constrains, but as I was adding dimensions, they didn’t show up like that, only showed the redundancies once I went to open the sketch to export as dxf.
Once I get the initial shape and create the planes for the brim, wall, blade, middle extrusion, I do export as dxf so I can import and scale down. From there, I’d scale the entire thing appropriately, then readjust the brim, wall, and blade to be the same size as the original model (smaller and the 3D printer has a hard time).
The issue is, I’m clearly not constraining things efficiently, so it takes forever to redo the brim, wall, and blade size to fit.
What is a better way to approach this? There has to be? Thanks in advance!
https://cad.onshape.com/documents/ebb5c7ba27d8716af43942b6/w/4334498cd669eb6d85b016ac/e/1cb8ee3405aefb161ff8fc77
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,895
    You're trying to do too much in one sketch. Create the outline (and maybe eyes) in one sketch, then extrude, shell, sweep brim etc.
  • dirk_van_der_vaartdirk_van_der_vaart Member Posts: 560 ✭✭✭
    Left and right are identical, so only create one half.
  • EvanReeseEvanReese Member, Mentor Posts: 2,546 PRO
    you could just extrude it, then use the transform tool to scale it, then thicken it and model it however you like from there. That way you don't need to scale anything in the sketch. Here's an example
