How to create a selection to choose all the surface with specifc appearances
roy_yang375
Member Posts: 13 PRO
in General
I have edit some surface for different appearances to represent the machined surface on casting.
Now the question is how can I use these selections directly? Currently I can't choose these surface at once.
Or how can I just export these surface?
NeilCooke
Moderator, Onshape Employees Posts: 5,980
Hi Roy, it isn’t possible even with FeatureScript. If you wanted to export just those faces, you would have to create an offset surface of 0mm and then temporarily delete the solid using Delete part.Senior Director, Technical Services, EMEA0
Hi Neil, If I create an offset, then is that mean I need to select these surface one by one? It still a bit annoying to do that although I can use tangent or other method to reduce the number of clicks.
