Are sketch constraints broken?
randy_young
Member Posts: 22 ✭✭
I'm on Mac OS 10.15 and Safari. For the past two Onshape updates, sketches have quit showing the constraint icons, even if a sketch is over-defined, irrespective of the checkboxes. ie: on a new document, I make two squares in a sketch, with different dimensions. I then constrain the two squares to have an equal side. The sketch correctly goes red and marks the affected squares and their dimensions red, but the equal constraint icon does not show up, making it impossible to fix without deleting the affected component(s) and redrawing. Is anyone else experiencing this? See attached pic.
NeilCooke
Moderator, Onshape Employees Posts: 5,929
It’s possible, especially with Safari. Please try Chrome or Firefox or upgrade MacOS/Safari if you can.Senior Director, Technical Services, EMEA1 -
randy_young
Member Posts: 22 ✭✭
I've tried Chrome and it functions fine so it's definitely a Safari / Onshape bug. I've filed a bug report.0
