Sweep extrusion with curves in 3 dimensions
mark_dutton343mark_dutton343 Member Posts: 14
I have spent hours trying to sweep with both curves in xy and yz dimensions. I have looked at examples from others doing similar things using lofts, etc, but I can't fathom it.
My use case is I have a wire frame (a stand for an electric unicycle) that I want to attach a base to. It is bent to a certain shape that is all curves in multiple directions. I have drawn the curved paths from two faces (top and right), but I can't figure out how to make a sweep, or loft follow these two paths simultaneously to get the complex curve I need. My drawing is here https://cad.onshape.com/documents/640ed90f394fa65ae9f3cad8/w/a72a9f52503df2e8fe1ebb8b/e/22aae96bcb1efc9e8605b71e
I can sort of get where I want to go using a loft if I use one of the paths as a guide, but not both. I have tried attaching these paths to all different places, but I am totally stuck now.
I am hoping this is possible. It is otherwise a very basic drawing.
