Precisely, what drawing types can I import? List by file extension please.
bill_rainesbill_raines Member Posts: 1
I have had no luck importing these files; dxf, dwg, dae, fbx, ifc, obj, wrl, xsi. What am I doing wrong?
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,015 image
    @bill_raines Here is the list:
    https://cad.onshape.com/help/#web-help/translation.htm?Highlight=translate
    We also upload as storage any file extension.
  • kiwileekiwilee Member Posts: 8
    Note: They can't be used as sketches. So they are about as useful as an email attachment.
    It's a sort of reference document collator From what I understand.
  • james_thomas449james_thomas449 Member Posts: 3
    That link does not answer the question.... I would like to import the stl or another type  of file from my  electronic gerber file to save some time.  Can you list the supported types that can be imported to a plane in the drawing.
  • 3dcad3dcad Member, OS Professional, Mentor Posts: 2,482 PRO
    edited August 2015
    @james_thomas449
    That would be dxf and dwg.
    First you need to import them into your document, use + -menu in the left bottom -> import
    Then begin your sketch and select insert dxf or dwg, you should see your imported files (they need to be in same document).
    Perfect. Thanks! , last issue is that they are blank on the import tab across the bottom. they open fine in the native app...
    what 3dcad is explaining is that in the first stage of importation (in their own tab) drawings are not viewable. (I presume that is what you mean by "blank"
    That tab is simply a repository, like a file folder.
    The second stage of importation is from that repository into a part studio sketch in the same document, at which point a viable dxf or dwg will become visible.
    When I import the DXF to the part studio tab, via the  insert DXF or DWG the drawing does not show up in on that plane of the sketch...
    @james_thomas449 In the DXF/DWG are the entities in MODEL space or layout?  Currently these have to be in MODEL space to import.  If it is not working, please use the ? menu ->? feedback to send us more information.
  • john_gwinner099john_gwinner099 Member Posts: 2
    This ends up being pretty useless, however. I was hopeful you could handle FBX, but every time I click on it, it appears it just became storage. I looked up the documentation link and it's still not clear.
    With the state of industry, this is a vital question. Interoperability is a given.
    I have an ASCII FBX file that Blender can't handle, was hoping OnShape could.
    Apparently not??
    == John ==
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,175 PRO
    Apparently not??
    == John ==
    The files you are looking to import are I believe animation files for video games and movies and such. Onshape does not work with those files, nor does any other "mechanical CAD program." It's a completely different industry without overlap.
