Precisely, what drawing types can I import? List by file extension please.
bill_raines
Member Posts: 1 ✭
I have had no luck importing these files; dxf, dwg, dae, fbx, ifc, obj, wrl, xsi. What am I doing wrong?
https://cad.onshape.com/help/#web-help/translation.htm?Highlight=translate
We also upload as storage any file extension.
It's a sort of reference document collator From what I understand.
That would be dxf and dwg.
First you need to import them into your document, use + -menu in the left bottom -> import
Then begin your sketch and select insert dxf or dwg, you should see your imported files (they need to be in same document).
That tab is simply a repository, like a file folder.
The second stage of importation is from that repository into a part studio sketch in the same document, at which point a viable dxf or dwg will become visible.
