Precisely, what drawing types can I import? List by file extension please.
bill_raines
Member Posts: 1 ✭
I have had no luck importing these files; dxf, dwg, dae, fbx, ifc, obj, wrl, xsi. What am I doing wrong?
@bill_raines Here is the list:
https://cad.onshape.com/help/#web-help/translation.htm?Highlight=translate
We also upload as storage any file extension.Lou Gallo
Sr. Director of Product Definition. UX and Support0 -
Note: They can't be used as sketches. So they are about as useful as an email attachment.
It's a sort of reference document collator From what I understand.0 -
That link does not answer the question.... I would like to import the stl or another type of file from my electronic gerber file to save some time. Can you list the supported types that can be imported to a plane in the drawing.0
@james_thomas449
That would be dxf and dwg.
First you need to import them into your document, use + -menu in the left bottom -> import
Then begin your sketch and select insert dxf or dwg, you should see your imported files (they need to be in same document).
//rami1 -
Perfect. Thanks! , last issue is that they are blank on the import tab across the bottom. they open fine in the native app...0
what 3dcad is explaining is that in the first stage of importation (in their own tab) drawings are not viewable. (I presume that is what you mean by "blank"
That tab is simply a repository, like a file folder.
The second stage of importation is from that repository into a part studio sketch in the same document, at which point a viable dxf or dwg will become visible.0 -
When I import the DXF to the part studio tab, via the insert DXF or DWG the drawing does not show up in on that plane of the sketch...0
@james_thomas449 In the DXF/DWG are the entities in MODEL space or layout? Currently these have to be in MODEL space to import. If it is not working, please use the ? menu ->? feedback to send us more information.Lou Gallo
lougallo said:@bill_raines Here is the list:
We also upload as storage any file extension.This ends up being pretty useless, however. I was hopeful you could handle FBX, but every time I click on it, it appears it just became storage. I looked up the documentation link and it's still not clear.With the state of industry, this is a vital question. Interoperability is a given.I have an ASCII FBX file that Blender can't handle, was hoping OnShape could.Apparently not??== John ==0 -
The files you are looking to import are I believe animation files for video games and movies and such. Onshape does not work with those files, nor does any other "mechanical CAD program." It's a completely different industry without overlap.john_gwinner099 said:lougallo said:@bill_raines Here is the list:
