cannot open up model
hello,
from my work computer (lenovo thinkpad), I cannot open up the model (tried both with edge and chrome), I can log into onshape main page, but whenever i tried to open up any model, it would say onshape not connected, refresh brower (which doesn't work of course)..  I can access the model without any problem from the same network through a window surface pro computer.  both computers are configured the same by IT department..  what do i need to change on the lenovo thinkpad ?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,933 image
    If you run https://cad.onshape.com/check I bet it says no websocket connections. That is usually the cause - some ports closed on the firewall either on the computer or on the network. Strange that it works on the Surface Pro though.
  • peter_williams834peter_williams834 Member Posts: 4
    when i jumped back on surface pro the next day, onshape does not work anymore, and i tested both computers, both had the websocket connection issue as you mentioned. thx for letting me know.
