Material library for simulation
Adam_Micha
Member Posts: 17 ✭✭✭
Hi,
To use the simulation functionality it is of course important to have the correct material properties.
We can see that it is possible to add this manually now (previously it was only category, name and density that were supported) but is there any pre-defined material library that can be used or must all this information be entered manually for each material now?
NeilCooke
Moderator, Onshape Employees Posts: 5,967
The material library was updated at the same time so all the info is there in the Onshape Standard Material library.Senior Director, Technical Services, EMEA2 -
Adam_Micha
Oh right. Is there any way to edit this? The old style material library was just a CSV and the new one lacks some of our common materials.
EDIT: Now I found how to get to this. It was an issue of PEBKAC.0
