I'm kidding about the check, but serious that Onshape should make the rest of your modeling easier if your products are similar to what you're showing above. The only other area I could see Rhino winning is in making a flat pattern of the parabolic-looking awning. With OS sheet metal it would have to be made of a series of arcs to work (I think)
Onshape has supported structures like that in sheet metal for a while now
@kael_c here is a link to Evan's Attractor pattern post:
https://forum.onshape.com/discussion/14301/new-feature-attractor-pattern
That page contains links to a tutorial video and to the feature where you can add it to your tool bar.
RENDERCAD
