In-Context not working
nenad_bojcetic
Member Posts: 14 EDU
in General
Hello all,
I have a short question, does anybody have idea why In-context design is not working in this example?
The in-context message above the model is in wrong color and in-context name is not showing above Default geometry.
I created a new assembly and I do have enough disk space.
Best regards!
EDIT: it will always take you to the Part Studio - that's how it works.
If you edit one of the parts and make a reference to one of the ghosted parts (the in-context geometry) then a context will be created, but it makes zero sense in this scenario.
This one explains all https://learn.onshape.com/courses/managed-in-context-design
"Edit in-context" from the menu, on one of the components but I did not get a new context. Can you tell me what am I doing wrong, I clearly misunderstood how the in-context works.
If you can see the geometry the context is there. The entry doesn't get created in the list until you actually reference context geometry. As soon as you use something from the context it will create it.
