How to define a spiral around a hollow cylinder, without "overhangs"
For threads, I usually extend the helix beyond the cylinder. Then split it like @eric_pesty said. You can probably smooth out the transitions with fillet after it is split then joined to the cylinder.
I moved to an inner thread design because it suited the specific application better, but I also need an external thread one so I'll keep working on that.
@NeilCooke thanks for the link, it looks quite close to what I'm trying to achieve, I'll fork it and play with it, I don't quite understand how it works yet.
