studycadcam 1043
roland_koeckel
Member Posts: 11 ✭
Hi
I am learning onshape coming from fusion 360 and I must say onshape is the better tool for me especially when it comes to making changes to the parts history.
Please see the following ashtray from studycadcam 1043 which I designed in https://cad.onshape.com/documents/81182ecb7da0fec679a85444/w/8e03ecf42ca2b0a6f0f5b146/e/89b751dc3675dc6c5317c91f
I tried to do this with sweeps but always got collaps errors. So this is the way I designed it:
- 10 deg drafted extrusion to the top
- outer fillets
- sketch with inner dimensions of the ashtray
- 10 deg drafted extrusion downwards for the inside
- sketch for the cutout and remove extrusion follwed by circular pattern
- fillets
- shell
- inner fillets
steve_shubin
Member Posts: 1,118 ✭✭✭✭
Here is one wayroland_koeckel said:Is there a better way to designing 1/8th or 1/4th of the part and then do mirrors or circular patterns?As to if this is better.
I’ll just say there’s less features. And it done with the mirroring that you were talking about. There’s a bunch of ways this could be done.0 -
EvanReese
Member, Mentor Posts: 2,864 PRO
Um smoking is bad for you, but here's another take. I think your feature tree is already pretty minimal. You're not doing anything "wrong" but there are almost always efficiencies to gain. I did write a custom feature called Multi Mirror for situations like this (with lots of help from @MBartlett21).
https://cad.onshape.com/documents/3c7316b4e60fd1e700f98e47/w/b40bc2e26e5353e9fccdd20e/e/39da8a15929a4d6de3ad318c
