Broken document?
carokhancarokhan Member Posts: 6 EDU
Hi!
I am trying to open this document:
https://cad.onshape.com/documents/9f76ed52415ba42144102ea3/w/745246a96f63473fe4aea34f/e/034743098df43a46ef3bf898?configuration=default&renderMode=0&uiState=63838cacfdd77b21d4c6c692 to edit (it's fine when viewing logged out).
When trying to open it, it just says it is not connected - "Onshape is not connected. Your document is saved. Refresh the browser to continue working on this document. "
I am unable to copy the document either - "An error occurred attempting to copy this document. Service unavailable. Please try later." I am also unable to restore to a previous version. This seems like a similar issue to:
https://forum.onshape.com/discussion/15829/document-broken
Has anyone seen something similar before and have a solution? Thanks!
    john_rousseaujohn_rousseau Member, Onshape Employees, Developers Posts: 362
    @carokhan please try again now. You should be able to open it.
    glen_dewsburyglen_dewsbury Member Posts: 595 ✭✭✭
    Took a minute or so but opened for me and let me move elevator up and down.
    Could be your machine or network connection.
    edited November 2022
    Yes, the document is fine to view I am unable to edit, copy, or restore to a previous version. Are you able to copy the document?
    I know it is not my machine/network as I am able to open and edit other documents created by me. Thanks!
    That worked, thank you! Was something wrong?
    Yes. There was an issue on our servers with that document.
