Combine Branches
Axel_KollmenterAxel_Kollmenter Member Posts: 420 PRO
How can I flip the B1 to be the new Main?
Best regards,
Axel Kollmenter
  • glen_dewsburyglen_dewsbury Member Posts: 1,000 ✭✭✭✭
    Select main as your working version and right click on B1 for merge. Unless I'm missing something in your question.
  • Axel_KollmenterAxel_Kollmenter Member Posts: 420 PRO
    edited December 2022
    Yeah, but then i got 3 options. If I click the highlighted one, its still different to the B1
    Best regards,
    Axel Kollmenter
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,844
    The third option will replace all tabs by default but you should still review all the rows below to make sure the action you want is correct. If you want to keep Main you should create another branch off Main before the merge from B1.
  • eric_pestyeric_pesty Member Posts: 2,130 PRO
    @Axel_Kollmenter
    Not 100% sure if this is what you are asking but if you want "Main" to be come exactly identical to the current B1, the way to achieve this is to restore V2 (the one B1 started from) to the main workspace and then merge B1 into Main.
    Yes, I have already tried all that. It all worked but the bevel feature does not drag with...
    Best regards,
    Axel Kollmenter
    That's odd, might be worth submitting a ticket as it sounds like something isn't working as intended...
    Was the bevel feature originally in Main and then deleted? If so, merging the same feature from B1 will not make it magically appear again unless you overwrite the tab completely.
    No the last construction change in the Main was on 24.10. Since then I worked at the B1 branch. The bevel feature was made in the B1 branch.
    I mean the following feature. I dont know how its called in english
    Best regards,
    Axel Kollmenter
  • sebastian_glanznersebastian_glanzner Member, Developers Posts: 446 PRO
    @Axel_Kollmenter
    Can you copy the Part Studio from one branch and paste it in the main branch?
    @sebastian_glanzner haven´t tried this yet but i will try today. I finished all Draft angles and I´m happy how it is. I try to rebuild the problem and then Ill open a support ticket.
    Best regards,
    Axel Kollmenter
  • Matt_LoMatt_Lo Member, Moderator, Onshape Employees Posts: 15
    I am answering your question through the support ticket.
