cannot change dim,ensions on a sketch
when I create a sketch using a box when I go to dimension it I cannot change the dimensions as it was drawn. I click in the numerical box and change the dimension to what I want but when I hit enter it changes back to what it was without changing the dimension of the sketch. what am I doing wrong. I have tried to dimension a line and also selected two points and changing the dimension.
andrew_troup Member, Mentor Posts: 1,585 ✭✭✭✭✭
3dcad said:https://support.google.com/chrome/answer/157179?hl=en&rd=2
Normal reload:F5 or Ctrl+R Reloads your current page.
Shift + reload:Ctrl+F5 or Shift+F5 Reloads your current page, ignoring cached content. 5
I was working in I.E. When I switched to Chrome browser it works. Thanks for the help, stupid of me.
I have the impression there's an even more fundamental reload for cases where a simple tab reload does not fix a problem, which is to hold down "Shift" while clicking on "Reload"
Maybe someone with browser expertise might comment on this?
Normal reload:
Shift + reload:
