Problem with placing multiple fillet
Lets say i'm designing a basic cube and want to fillet the edges on the left and right side of the cube.
i click on fillet tool and select both sides. this is were i get the error message.
i have to open a new fillet tool every time and only select one side at the time!
this was not a problem when i first started with onshape
This should not be an issue. Can you provide the error message and a link to your document?
For complicated parts that need fillet stacking, I use Multi fillet which is a derivation of Evan's Selection fillet. However, you shouldn't need either of these for a simple cube.
I have just learned a new trick though, it would never have occurred to me to select the vertices!
