Hide transition lines in a part or assembly
ricardo_raimondoricardo_raimondo Member Posts: 66 ✭✭
I designed the part below and used several tools to make the shape. As a result, what I called transition lines (maybe the wrong name) appear wherever parts join each other or fillets are added. As a view for a screenshot that looks really ugly. The question is: Is there any way to hide those lines in the online version of onshape?
  • wayne_sauderwayne_sauder Member, csevp Posts: 630 PRO
    @ricardo_raimondo
     In the drop-down menu of the small cube menu in the upper right corner, select the shaded with hidden edges. I think that should take care of your problems.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,933 image
    Depending upon what you are doing with that geometry, it might be worth revisiting to see if you can tidy it up in earlier features. Bad geometry can lead to problems later on. Also,120 features seems a little excessive.
