Internal end cap for tube with oblique end
Henk_de_Vlaam
Member, Developers Posts: 265 ✭✭✭
I tried to make an internal end cap at an tube with oblique end. That gives an error. Is it still possible or has this functionality to be added at the End cap feature?
I made the end cap by hand.
This is what I mean: https://cad.onshape.com/documents/2a4c4901bcb8d5d01924a7c0/w/7f442f5a6fc06c4d0952b137/e/6b6abbb1dd2ef332d1b6a55a?renderMode=0&uiState=63a1674d4e21885bca4ed0be
Henk de Vlaam
https://cad.onshape.com/documents/a120e79983b6635ad0751e99/w/478fb4d38b46a5c3a68e7511/e/c67be154d974b38e0d4b89d5
Here’s one way
Use FILL
And then use an EXTRUDE FS that allows you to set the direction
And within that extrude dialog, to set the direction, I selected the surface of the tube
https://cad.onshape.com/documents/a120e79983b6635ad0751e99/w/478fb4d38b46a5c3a68e7511/e/cc9c219a5cb8f0313acef38c
I added a couple more features
I made a sketch at the top surface of the cap
I used the USE tool to select the outline of the top and bottom of the cap
Then I used extrude set to INTERSECT
Will this work for you ?
This is exactly the shape I made (in a different way, with standard features) and what I like to have as additional functionality with the End Cap feature.
