Surface loft
in General
Hi
I'm trying to create that "Hair dryer nozzle" but unfortunately I didn't succeed to create loft.
I tried to use "Path" "Guide" - but it doesn't work.
I'll appreciate if someone can help me
Thanks
Amir Livneh
Thanks
Amir Livneh
MichaelPascoe Member Posts: 2,415 PRO
Best practice here will be to use two different parts. This will allow you to have a simple loft for the flat portion of this nozzle and a revolve for the attachment area.
From the reference picture, you may not even need a loft:
https://cad.onshape.com/documents/7c7d03729cb51aa78d568807/w/9d32cdc4b62ed16bee330de7/e/5bdd8e03446d9ea22309b55c?renderMode=0&uiState=63b315746271ca41bd568643
CADSharp - We make custom features and integrated Onshape apps! Learn How to FeatureScript Here 🔴1
But, it is still not the same.
I wonder how to build it using Loft command
Thank you guys
Finally I made it with 2 different loft
(and it is an exercise from Solidworks)
Thanks for your support
Here is one way to loft part A:
https://cad.onshape.com/documents/7c7d03729cb51aa78d568807/w/9d32cdc4b62ed16bee330de7/e/5bdd8e03446d9ea22309b55c?renderMode=0&uiState=63b416ad632e722d520c1c13
