Onshape 3DConnexion Spacemouse Chromebook Integration?
in General
I'm trying to use my Spacemouse wireless with Onshape on a Chromebook for a school course. Is there a way for this integration to work? Chromebook natively supports Spacemouse for their web apps, like Google Earth, but when I try to use it in Onshape, nothing happens. I have tried to install the 3DX drivers via the Linux command line for Chromebook, but I get various errors, including some directories being missing and not having a program called Red Hat EL 7 (which I tried to install but couldn't). I have an education subscription to Onshape. Is there an alternative way to do this? Some menu I'm missing? Thank you for the help.
Error: 3dxsrv.c :: startupCommandLine(), authGetUser(), failed to get user.
This occurs even when I run the command with administrator permissions (sudo). I think it may have something to do with Chromebook being unable to detect USB devices through the Linux environment. Is there any way to fix this?
Spacenav web site (sourceforge.net)
