Drawing - Cutting plane using ISO 128
Mr_DevismeMr_Devisme Member Posts: 6 EDU
Hi,
I can not find the option to use the arrows of a cutting plane following ISO 128
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,969 image
    You have to choose an ISO drawing format to see this style of section line.
  • Mr_DevismeMr_Devisme Member Posts: 6 EDU
    Thanks for the quick reply - Could it be that this only shows up using the First Angle projection? I am using ISO and Third Angle and the arrows are pointing the ANSI way
    Huh, you're right. Supporting all drawing standards like BS8888 has been on the todo list for a long time. Please create an improvement request.
    Thanks, improvement request submitted
