Making a solid rounded cap?
Hello. I am quite new to Onshape, and I'm having trouble figuring out how to create a solid dome shape on the end of this surface so that it is a rounded cap. Could anyone explain how I would go about doing this?
Thanks.
  • abstractonautabstractonaut Member Posts: 4 EDU
    edited January 2023 Answer ✓
    S1mon said:
    Assuming this shape was made with a revolve, the simplest solution would be to add an arc to the revolved sketch.
    It was made with a loft. Would this still work?
  • S1monS1mon Member Posts: 3,346 PRO
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,868
    Loft to a point, but much faster to start again with a revolve like @S1mon says. Easier and more accurate.
    This worked, thank you.
