Reset Name of part
MBartlett21
Member, OS Professional, Developers Posts: 2,064 ✭✭✭✭✭
How do I reset the name of a part so that I can configure it using featurescript?
EDIT: Also reset any of the other properties.
konstantin_shiriazdanov
Member Posts: 1,221 ✭✭✭✭✭
looks like if you once set the property manually renaming features have no more any affection on it, though if you only change part name with renaming feature multiple renames are possible
5
Yes, I did, but since I had already set the name, it didn't work
my current terrible work around is to supress the feature that initially creates the part, remake it in a new feature and then work through the whole feature tree to update all the references. only then i remove the original feature and can i use the 'partname featurescript'
kind regards
Jelte
