Modelling drafted sweep
rafael_amenrafael_amen Member Posts: 2
Hi!
I need to model a sweep with varying cross section, more specifically an adze handle.
I only find constant cross section sweeps. How can I do?
TIA,
Rafael
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,065 PRO
    This may not be the best answer but here it goes.
    Sweeps will typically be a constant diameter along the path. Some programs may have a draft sweep, but I don't think it's ever come up for me to look for it.. :)
    If you want to make it match an adze handle, you may want to try a loft with guided curves instead.
    You will have to create a sketch plane at each significant cross-section and work your way up to the end.
    There is a feature script somewhere that lets you make an array of planes along a path.
    Then do a loft with guided curves.
    Below I did a quick mock up of the concept with just the start and end planes and one guide spline, each end has a different size ellipse.
    This looks messy, but with enough massaging I'm sure you can get what you are looking for.
  • sandy_koukersandy_kouker Member Posts: 1 ✭✭
    Just to add value: If you need to hollow it, the only stock way I found: Offset that Loft, then Thicken the resulting surface.
