FS Box joint; Why maximal 12 pins?
DI_PE
Member Posts: 6 ✭✭
@NeilCooke,
I like to use more than 12 standard and dovetail pins with your FS Box Joint. However, is it correct that the limit is 12. Is there a reason for that?
OptionsNeilCooke Moderator, Onshape Employees Posts: 5,419It was only there so that if you accidentally typed a very large number you wouldn’t have to sit there while it regenerates. I’ll change it to 200.Senior Director, Technical Services, EMEAI1
In the configurable box that I made I had pins of 8 mm and edge lengths of >399 mm, which needs >24 pins.
So, Is there any limit needed and why? In other words: can the limit be removed?
I think this will be more then enough. Thank you very much.
