Adding struts between non planar tubes
WaldPinkler
Member Posts: 25 EDU
Here's the model
I'm having a tough time trying to put support struts between these tubes that aren't aligned. How do I go about it?
I feel like I'm hacking things together with projected curves and bridging curves.
The sketch in the picture below shows where I'd like the struts.
I would model this in half and boolean the middle pipes later.
And for the strange curved pipe's try placing a 3 point plane first in the position you want.
For example you can create a straight member between any two points so you wouldn't have needed any of the bridging curves...
That said, I'm not sure which other tubes you are having trouble with...
I was having trouble with the end section as in the sketch. There were small gaps in the horizontal bar to the main frame because of where I was trying to join it to. I couldn't get the inner struts to position correctly.
I created the lower rear part with the sketch from the first post and the one below. I aligned the end points with a horizontal constraint to the same in first sketch above.
Just do the same with the struts? The slight angles makes it hard to find which vertex I'm looking for. I could make more sketches but that feels awkward to make changes.
I tried a loft between the frames, a ruled surface for the braces then intersection curves. It's faster and looks ok. I don't know if the intersection curves are straight though, it depends on the loft.
I can't get the same with the rear section because it's hard to select and fill the awkward shape.
Making a plane 45 degrees to the first sketch worked for the braces. I have to project each separately otherwise it fails. At least it gets me where I want.
https://cad.onshape.com/documents/9bddf41e8d9f461ea10840f8/v/131849b5116cc7c1367e35ae/e/79da65d8fe27fc8ee2900deb
3d sketch model
I still run in the same difficulties with the braces. The fillets make it worse.
The alignment at braces is terrible. I could extend them past frame then project the curves and use the 3d sketch tool to shorten. It's a big hassle if any geometry changes!
Look for Arch studio copy and see what happens after insert of Plane 1
https://cad.onshape.com/documents/31f3460d8bcce0c90a33e9f5/w/f7f8882f01f129a35312d5b3/e/38e5537477a3939c5b8f5fda
