PIN IN CURVED SLOT
in General
Is there a way to put a pin in a curved slot and run it end to end?
Also need to be able to rotate the pin as it moves in the slot.
https://cad.onshape.com/documents/57acdfaae4b005c413ed9b6f/w/3fd585a46d3af1b3ba413c53/e/c23e5f039ae4d2f5baec1c92
Used a bunch of tangent mates and a cam to turn the shaft.
Tricky application.
- Create a dummy surface on the tip of the pin
- Add a mate connector to the center of the dummy surface and offset it the radius of the slot (or create it in context at the center of the slots' arc)
- Add a revolute mate between the dummy's mate connector and one at the center of the slot & add angle limits to keep it in the slot
- Add a revolute mate between the dummy's center and the pin's center
Hope this helps!https://cad.onshape.com/documents/507a0b6f5598526b0901568f/v/553abcc1fc688cff8743522a/e/96531f6f9ec76ed5689e4b08
Not rolling contact. There's a cam driving an arm attached to the pin.
LICEcap took a picture of the desktop right through the browser image.
Anyone know what I did wrong?
So here is the pin in curved slot driven by a cam.
