I am trying to create a conical funnel, and then add some parts to it.
Hi, I am trying to have a conical funnel so it is hollow inside, and then to add some parts to the outside. However trying either a revolve, or a loft does not allow me to either wrap onto the surface, or even when i extrude the cone shape and try to shell it, this dosen't work either. What am i doing wrong?
Although the second document below is not a cone, this is another way of going about wrapping something (so to speak) onto a shape other than a cylinder
https://cad.onshape.com/documents/8de29271dc9230d98d069a3d/w/415e38108d1d12aa4225d1cf/e/0167861aeece980bafc1cc79
https://cad.onshape.com/documents/58da25001def5009a08d2fe7/w/440c2dd5958d1608e745ccfa/e/d7bd43746bda47e5ea0b9a0c
Regarding the document directly above, in the discussion at the URL below, you will find a breakdown on the difference between the 4 part studios in that document titled Bowl with Circle
https://forum.onshape.com/discussion/19981/need-up-with-wrapping-a-feature-across-the-right-plane-of-an-cylinder
