Advanced Part Design Exercise: Vent
jamescbonney
Member Posts: 14 ✭✭
I am having a problem with step 16 in this exercise. I have followed the instructions for the step, but the result of the feature pattern in my part studio differs from that shown in the example, so I must be missing something.
There is a hint in the sketch step to dimension from the vertical and horizontal construction lines to the radius of the slot rather than the end point of the arc. I have tried changing the vertex selected for the dimension and it did change my result, but I did not get the result shown above.
Below are screenshots of the sketch, first circular pattern, and the troublesome second circular pattern.
Here is a link to the document: https://cad.onshape.com/documents/c6d77c61f4665964b85bd18f/w/4c54d3eb1fb2eab39d5f4b28/e/c89354e2446653e5ef20b831
Here is a link to the exercise: https://learn.onshape.com/learn/course/advanced-part-design/advanced-features/exercise-vent?page=2
Optionstim_hess427 Member Posts: 648 ✭✭✭✭Maybe the highlighted dimension is supposed to be perpendicular to the construction line, but in the messed up model its setting a vertical distance between the center of the arc and the endpoint of the line.
Try erasing that dimension and re-doing it, but make sure you select the construction line instead of the end-point on the line?
1 -
OptionsEvan_Reese Member Posts: 2,066 PRO@tim_hess427 was right. the dimension needed to be between the arc center and the line, not the endpoint of the line.
It feels confusing because the result is the same in this sketch, but the results in the patterned sketches are different. When it's dimensioned to the point, the patterned sketches start to do this because the dimension is still vertical.
Evan Reese / Principal and Industrial Designer with Ovyl
Website: ovyl.io2 -
Optionsbruce_williams Member, Developers Posts: 842 PRO@jamescbonney
I was confused on that for a bit also. It is not relevant if you choose arc center or vertex of the slot centerline. What the others are talking about is the horizontal construction LINE, and not choosing its vertex.
www.accuratepattern.com2
Website: ovyl.io
I have made the document public.
I will check back to this exercise and see if the suggested solutions resolve the problem.
Website: ovyl.io
To select the arc center did you hover over the end point of the arc and then move to the center?
I right clicked and used the select other option and tried the available options, but apparently I did not have luck selecting arc center.
Website: ovyl.io
Ah! I see now! I misread the clue.
It would be much easier to help you if you can share a public document. These kind of patterns are tricky and little details make a big difference.
