Can a drawing view reference a "named" view from a part studio?
dave_franchinodave_franchino Member Posts: 78 ✭✭
Hey Folks,
Is it possible to create a drawing view that references a named view in a part studio?  A common issue is a part that's designed off-angle from the orthogonal views in a part studio.  I can easily create a true view normal to the part in the part studio but that named view does not appear to be accessible when I go to create a drawing which is a real pain. Am I missing something?
    edited February 2023
    Hi @dave_franchino, see these steps below:
    • Make sure the drawing has been updated with the yellow icon at the top left.
    • Hard refresh your browser tab with the drawing sheet. (Ctrl + Shift + R)
    • Right click the drawing view > View orientation.
    RENDERCAD
  • dave_franchinodave_franchino Member Posts: 78 ✭✭
    @MichaelPascoe - it doesn't seem to be working unless i don't understand the relationship between part studios, parts and drawings (which is very possible!).
    Here are the named views available in the Part Studio I designed the part in:
    But when I go to the drawing view none of these are available even though the drawing shows as up to date.
    Weird - tried your steps - not working for me. I can't do ctl shift r - that's a hot key for another program but I logged off and logged back on.  is that the issue?
    OK.  Very odd. I duplicated your test and it worked. But it's not working on my current file.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,991 image
    You need to update the drawing so that it can read the latest data from the Part Studio.
