Reverse Break View
From what I have read and experienced, the Break View tool only allows you to show what is outside the two jogged lines placed in the drawing view, with what is between the two jogged lines removed/hidden.I need the reverse. I need to show what is between the two jogged lines placed in the drawing view, with what is outside the two jogged lines removed/hidden.Is there a way to do this, other than creating a custom part where I remove the geometry before inserting the view?
Crop will not work as a workaround, because Crop doesn't work on a Section view, and the Crop does not carry over from the Orthographic view to the Section view. Speaking of the Crop tool, is there a way to use straight line sections or a rectangle, to give more control to the shape of the crop?
Thank you in advance.
So far, these are the limitations we know about and will get to with the conservation occurring here:
1) An ability to break a section view
2) An ability for parent/child relationships on views with breaks
3) An ability to create dependent views of dependent views, crop views of section views for example
4) An ability crop not just a closed spline region but also a rectangular or circular one
5) An ability to detail not just a circular region, but also a closed spline or rectangular one.
An inverse of a break view is not really an industry practice, so I'm hesitant to say anything about that - unless there are examples and compelling arguments to be better than what is generally accepted. I suspect a rectangular cropped view of a section view would be more what @Kurtis_Harris wants. Keep in mind, closed spline regions are often what's used because it becomes obvious to everyone that the spline outline is not the part, but the view border. On rectangular cropped views... to distinguish would users here want an ability to show the crop border as part of the view (similar to detail view borders)?
An ability to hide (or format?) the detail view circle that is around the view (not the one that defines where the detail view will come from)
I turn off all the frills in SW and it still preforms like a wet sack of @#&* PDFs look nice tho.. guess that counts for something
Cropping the vies with a spline is tedious and a bit janky when drawings get big. We often run out of the allocated memory on our drawings. The break view is super quick.
Why do we need it? Very often in construction industry, drawings of a product need to show part of the context or the structural interface with other parts in the build. There is never a natural place to stop drawing in the layers of construction, and we never want to spend much time modelling geometry that is not ours. The suggestion of a reverse break view (although only in one dimension) would provide a very easy way cropping the context. Or can we have a rectangle or polygon fence tool to the crop view tool please?
@pete_yodis, since 2019 I think many of your 1-5 list have now been done, but number 4 seems not have made the sprint list yet?
Thanks
