Dimensions not changing from inches
Mrs_S_Wollerton
Member Posts: 4 EDU
I am a DT teacher using Onshape in the UK and when students set up their accounts they forget to change the dimensions to millimetres which is what we work in. I go into the account settings and change them there - this sometimes works but often doesn't. I have tried getting the students to sign in and out again, close the browser but it still defaults back to inches. And when I go and look at their account settings it's still in inches.
NeilCooke
Moderator, Onshape Employees Posts: 5,912
The preferences only work for new docs. For existing ones, you can change the units inside the doc using the "hamburger" menu, top left.Senior Director, Technical Services, EMEA0
