How to model the corners of a range hood knob?
maarten_duriemaarten_durie Member Posts: 11
Dear community,
I'm trying to model a range hood knob (FDM 3D printing). To get an accurate look of the original knob, I'm struggling with some rounded corners, see image below & link to model here: https://bit.ly/3Kyw0JG
Does anyone has an idea to get those corners, without the need to create surfaces?
Using variable fillets on the solid doesn't bring any results.
Using Fill on some edges doesn't create a nice surface that can be used.
It seems to be a similar challenge as the Dice corners, see image below.
How would you model this while keeping the edges intact in the middle?
