Extrude to the point on a sketch.
I am extruding the face, and would like to specify extrusion length by a point on a sketch.
I've got a front sketch (that I am extruding) and the sketch on the right plane that constructs the length of the extrusion (using references to from sketch). I see there are options to extrude up to face/part, but I can't figure out how to extrude to the point.
https://cad.onshape.com/documents/63f6ce65081548718676648b/w/6f1ba9b1654a4cb8837b0371/e/d37b17c7802348caab2e7869
I say potentially laborious, because it may need provision of a dedicated plane through the vertex as well as a dedicated sketch, whose endpoint is constrained to the vertex in question, and whose direction is normal to the plane of the extrude profile.
