Improvements to Onshape - February 27th, 2023
Roy_MutalikRoy_Mutalik Member, Onshape Employees Posts: 38
edited March 2023 in New in Onshape
In spite of February being the shortest month of the year, we're excited to bring you a second release this month! We hope you enjoy some of these drawing and usability improvements.
As a reminder, Onshape Live, our annual virtual user conference, is THIS WEEK! Join us March 1st (Americas) or March 2nd (Europe) to catch all the action!
If you haven't done so already, please register HERE.
https://onshape.wistia.com/medias/9slw0tov4e
We'll see you all there!
GENERAL IMPROVEMENTS
LOFT SHOW CONNECTIONS IMPROVEMENT
When creating a Loft feature, the "connections" toggle now shows implicitly created connection points (connections created by default). This assists in troubleshooting instances of twist, and provides more clarity when creating your own connection points.
https://onshape.wistia.com/medias/3kp1x43lsu
EXTEND - ELLIPSE
Extend or complete a partially sketched arc or ellipse, even if it was previously trimmed.
https://onshape.wistia.com/medias/b43d7z79gw
DRAWINGS IMPROVEMENTS
MAXIMUM DRAWING SIZE
The maximum height and width of an Onshape drawing sheet has now been increased to 1800 inches (150ft / 45m). This allows you to create 1:1 scale drawings of even larger parts. These outputs are often necessary for operations such as laser or water jet cutting.
https://onshape.wistia.com/medias/xxept5ecsy
FLAG NOTE SIZE
The size of Flag note symbols may now be adjusted. Additionally, the default size has been increased to create cleaner results for Flag note lists that contain more than 9 items.
https://onshape.wistia.com/medias/y4j86ykanv
HOLE CALLOUT LIMITS ON INSPECTION REPORTS
Hole callout tolerances of upper and lower limits are now mapped to their independent columns in an Onshape Inspection Report.
https://onshape.wistia.com/medias/w44cg6cl31
FEATURESCRIPT IMPROVEMENT
FEATURESCRIPT IMPORTS CONTEXT MENU
Right-click on any part of an Imported FeatureScript to update its linked document reference.
https://onshape.wistia.com/medias/14arsdxagw
ANDROID IMPROVEMENTS
EXPORT DIALOG
The Export dialog on Android devices has been updated to more closely match that of the web browser.
CREATE VERSION FROM INSERT DIALOG
Similar to the browser, you may now create a version directly from the Insert dialog.
LEARNING CENTER IMPROVEMENTS
VIDEO UPDATES
Take a look at some new and updated videos in various Onshape courses:
  • MichaelPascoeMichaelPascoe Member Posts: 2,329 PRO
    edited February 2023
    Thank you Onshape team!
    We'll put that FS improvement to good use :)
  • xTimRicexTimRice Member Posts: 61 PRO
    Love the FS improvement. Loft twist is pretty neat too.
    Handcrafted furniture in Boston
    https://thesmoothcut.com/
  • mlaflecheCADmlaflecheCAD Member, Onshape Employees, Developers Posts: 181
    Join Richard Doyle and me for the Livestream at 5:00 pm Eastern Time.  What an excellent way to wrap up a Monday!
    Youtube:  https://www.youtube.com/watch?v=bvaR_3shmAw
    Twitter:  https://twitter.com/Onshape
    LinkedIn:  https://www.linkedin.com/events/7036085267501342720/comments/
    Regards,
    Mike LaFleche   @mlaflecheCAD
  • S1monS1mon Member Posts: 3,326 PRO
    @eric_pesty
    Either it's exactly what you said, or they're saving some things for Wednesday for Onshape Live.
  • Cedric_EveleighCedric_Eveleigh Member, OS Professional, csevp Posts: 68 PRO
    "The maximum size of an Onshape drawing sheet has now been increased to 1800 inches square (150ft)." Can you please provide info in metric units? Not everyone uses those dumb imperial units.
    I wasn't expecting an update until after the event honestly :)
    1800" = 45.72m
    Per the video that's per side, not square area units (which it almost sounds like in the text).
  • jason_1jason_1 Member Posts: 28 PRO
    @Cedric_Eveleigh I was confused by your comment because it looks like this to me
    anyway, this is a plug for https://github.com/m1l/Everything-Metric it's a really great browser extension even if it occasionally messes up the line spacing on McMaster
  • Ivan_DeetlefsIvan_Deetlefs Member Posts: 23 ✭✭
    I like the flag note update but there is still no flexibility regarding the numbering format.
  • wout_theelen541wout_theelen541 Member, csevp Posts: 198 PRO
    Hmm, is it just me or does this one seem a bit "light"? Almost like the "headliner" improvement didn't pass QC on Friday and had to be left out until next time!
    I guess we've been spoiled with all the stuff we've gotten over the last few months!
    I guess they're releasing these light updates since they're pretty and not as fun/not really worth it to demo. Still not a bad update by itself I can make good use of the new courses, might save me from raising 1 or 2 tickets or will at least teach me something I wasn't aware of.
  • don_williams909don_williams909 Member Posts: 146 PRO
    Some seriously good improvements here.  Love the ellipse trimming and the sheet size improvements.
    But still waiting for Arial font...
  • partsovenpartsoven Member Posts: 29 PRO
    Excellent improvements! Keep up the great work Onshape team!
  • gabriel_buttegabriel_butte Member Posts: 4
    wow so cool
    It says (150ft / 45 m)
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,862
    I edited it :)
  • bryan_lagrangebryan_lagrange Member, User Group Leader Posts: 867 ✭✭✭✭✭
    edited March 2023
    Is that a chorus of F5 button pushing I am hearing??? :)
    Bryan Lagrange
    Twitter: @BryanLAGdesign
    En este enlace podéis ver las Novedades de Onshape en español:
    https://youtu.be/Duns-HBJFeI
    Un saludo,
