Does the Introduction to Assembly Design Tutorial have the incorrect Center of Mass?
ken_bolandken_boland Member Posts: 3 EDU
I have been trying to complete the Introduction to Assembly Design Tutorial for 2 days. I retried it 5 times, trying to get the correct Center of Mass for the Universal Joint Flange. I finally decided to click an answer and then I see there is a Public Document I can check. When I checked the Public Document, the Center of Mass for the Universal Joint Flange does not match any of the answers in the self-check quiz. It did however, match the Center of Mass that I was finding for my attempts. I think the answers to the Self-Check question at the end need to be updated. See screen captures of the self-check quiz and the Center of Mass for the Universal Joint Flange that can be selected in the Public Document.
  • KatieHuffmanKatieHuffman Member, Onshape Employees, Developers Posts: 194 image
    edited March 2021 Answer ✓
    @ken_boland I believe you are correct- I think this has to do with the tolerances but I went ahead and changed the answers in the self-check question.
  • ken_bolandken_boland Member Posts: 3 EDU
    @KatieHuffman Thanks!
  • sam_malavesam_malave Member Posts: 2 EDU
    I am having trouble assembling the joint. Could you please link yours as a document I can make a copy of for reference? Thank you.
    @sam_malave
    there is a provided completed example link in the validation step of the exercise. once you submit an answer.
