grey outlines when parts are turned off
I have been creating a multipart assembly. My first one. When I turn off all the parts, grey outlines of part of the sketches remain. I guess these are in some way unconstrained or unresolved. Unfortunately, I don't know why. I've attached a photo which will show more clearly what I'm trying to solve. Any help would be much appreciated.
Thank you
https://cad.onshape.com/documents/52d53f8e9aa1021487a46b97/w/4ffaaa2d49790a43d24db5ad/e/cdad0f5d5b439bf600d99951
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,979 image
    In the sketch dialog, "disable imprinting" will remove the face you used for selection (the grey area) from the sketch.
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,577 PRO
    Or maybe just hiding the sketches is all you are missing?
  • glen_dewsburyglen_dewsbury Member Posts: 1,287 PRO
    I personally would like to see "disable imprinting" as the default.
  • S1monS1mon Member Posts: 4,023 PRO
    Vote for "disable imprinting" as default:
    https://forum.onshape.com/discussion/18004/default-to-disable-imprinting-on-new-sketches-or-remember-previous
    Remembering the previous setting would likely be the least disruptive, but if they ever expand the preferences page, this seems like a prime example of a polarizing setting which should make it there (along with orbit vs tumble 3D view spinning options).
  • jeremy_thompson016jeremy_thompson016 Member Posts: 4
    Thank you. It's easy when you know how!
