grey outlines when parts are turned off
jeremy_thompson016
Member Posts: 4 ✭
I have been creating a multipart assembly. My first one. When I turn off all the parts, grey outlines of part of the sketches remain. I guess these are in some way unconstrained or unresolved. Unfortunately, I don't know why. I've attached a photo which will show more clearly what I'm trying to solve. Any help would be much appreciated.
Thank you
https://cad.onshape.com/documents/52d53f8e9aa1021487a46b97/w/4ffaaa2d49790a43d24db5ad/e/cdad0f5d5b439bf600d99951
Thank you
NeilCooke
Moderator, Onshape Employees Posts: 5,969
In the sketch dialog, "disable imprinting" will remove the face you used for selection (the grey area) from the sketch.Senior Director, Technical Services, EMEA1 -
eric_pesty
Member, pcbaevp Posts: 2,541 PRO
Or maybe just hiding the sketches is all you are missing?0
https://forum.onshape.com/discussion/18004/default-to-disable-imprinting-on-new-sketches-or-remember-previous
Remembering the previous setting would likely be the least disruptive, but if they ever expand the preferences page, this seems like a prime example of a polarizing setting which should make it there (along with orbit vs tumble 3D view spinning options).
