File size limits free public account
I can not find the limits as regard file size or account file size and I can not see the size of my file or account files....
NeilCooke Moderator, Onshape Employees Posts: 5,862
See part b) of my rejected answer.Senior Director, Technical Services, EMEA4 -
S1mon Member Posts: 3,326 PRO
There's a dimension limit of overall size. I forget what it is, but I want to say something like 1 or 10 km?1 -
nick_papageorge_dayjob Member, csevp Posts: 961 PRO
don_b said:NeilCooke said:Just right-click a part or assembly tab and select move to document to see what it does. You can always undo it if you don't like the results.
One problem I am now having with this scheme is that there are different versions for multiple assemblies/ subassemblies and If I update to the latest version in all the documents/assemblies I lose parts, parts go out of position, and backtracking version history or further update complicates the problem....After finding and making a former version current and other massage of the assembly/part studios I currently have correct assemblies, part studios, plots etc. but they are of different versions.
Is there a way to fix this so an inadvertent update does not screw up the works?
don_b Member Posts: 150 ✭✭
Thank you.
I pinned the noted instance that showed "later version" (blue circle) I am not sure what happens if I need to edit that part considering it is in multiple version of assemblies or sub assemblies...and I do not understand how this different version problem occurred...perhaps because the part studios were referenced at different times when building a new sub-assembly. or delete an instance in an assembly that is in the assembly twice.....I found in help "updating references" which explains a lot of stuff....0
Is that a Parasolid limit or an Onshape limit?
Good advice here: https://learn.onshape.com/learn/article/10-essential-onshape-tips
Will I be able to have tabs from other documents in one assembly?
Will doing this ..."When a product is defined in multiple Documents, make links (or references) from objects in one Document to objects in a Version in another. You control when they update. This prevents the assembly corruption issues seen in file-based CAD systems."
does that allow other documents to be in one assembly .....is there a video about this?
Easy for me to fix but people should be aware
It would be nice if you added delete option to the teaser version of Kudo you show.
I revised the Autocad file to less than 3mb and still no joy…..so what is the file size limit for import????
From Support
"The limit is intentionally 8,000 entities "
