Improvements to Onshape - February 27th, 2023
Roy_Mutalik
Member, Onshape Employees Posts: 41
As a reminder, Onshape Live, our annual virtual user conference, is THIS WEEK! Join us March 1st (Americas) or March 2nd (Europe) to catch all the action!
If you haven't done so already, please register HERE.
We'll see you all there!
GENERAL IMPROVEMENTS
LOFT SHOW CONNECTIONS IMPROVEMENT
When creating a Loft feature, the "connections" toggle now shows implicitly created connection points (connections created by default). This assists in troubleshooting instances of twist, and provides more clarity when creating your own connection points.EXTEND - ELLIPSE
Extend or complete a partially sketched arc or ellipse, even if it was previously trimmed.DRAWINGS IMPROVEMENTS
MAXIMUM DRAWING SIZE
The maximum height and width of an Onshape drawing sheet has now been increased to 1800 inches (150ft / 45m). This allows you to create 1:1 scale drawings of even larger parts. These outputs are often necessary for operations such as laser or water jet cutting.
FLAG NOTE SIZE
The size of Flag note symbols may now be adjusted. Additionally, the default size has been increased to create cleaner results for Flag note lists that contain more than 9 items.
HOLE CALLOUT LIMITS ON INSPECTION REPORTS
Hole callout tolerances of upper and lower limits are now mapped to their independent columns in an Onshape Inspection Report.
FEATURESCRIPT IMPROVEMENT
FEATURESCRIPT IMPORTS CONTEXT MENU
Right-click on any part of an Imported FeatureScript to update its linked document reference.ANDROID IMPROVEMENTS
EXPORT DIALOG
The Export dialog on Android devices has been updated to more closely match that of the web browser.
CREATE VERSION FROM INSERT DIALOG
Similar to the browser, you may now create a version directly from the Insert dialog.
LEARNING CENTER IMPROVEMENTS
VIDEO UPDATES
Take a look at some new and updated videos in various Onshape courses:
New video on creating custom computed properties for the enterprise.
Document Management course
New video on creating and using aggregated assembly properties
New video on creating and using computed properties.
Onshape Assemblies course
Update to the Simultaneous BOM video to include adding custom computed properties and assembly aggregated properties in the table.
Onshape Surface Modeling course
New video on Mutual trim.
Remember: The updates listed here are now live for all users when creating new Documents. Over the next few days, these features will also be available in Documents created before this update.
Thank you Onshape team!
We'll put that FS improvement to good use
https://thesmoothcut.com/
Youtube:
Twitter: https://twitter.com/Onshape
LinkedIn: https://www.linkedin.com/events/7036085267501342720/comments/
I guess we've been spoiled with all the stuff we've gotten over the last few months!
Either it's exactly what you said, or they're saving some things for Wednesday for Onshape Live.
Per the video that's per side, not square area units (which it almost sounds like in the text).
anyway, this is a plug for https://github.com/m1l/Everything-Metric it's a really great browser extension even if it occasionally messes up the line spacing on McMaster
I guess they're releasing these light updates since they're pretty and not as fun/not really worth it to demo. Still not a bad update by itself I can make good use of the new courses, might save me from raising 1 or 2 tickets or will at least teach me something I wasn't aware of.
But still waiting for Arial font...
It says (150ft / 45 m)
It can seem that there is always some sort of "headliner" improvement with releases, but we don't plan it that way. Essentially we have a release cadence and if new functionality is ready, we ship it. We don't slow down or accelerate anything for making releases sound better or worse than others. We just usually hit a groove where there is a mix of new functionality of varying complexity that is ready at the same time.
Twitter: @BryanLAGdesign
