Help with sketch constraints
mike_hockings
Member Posts: 15 ✭
I am trying to make a simple bracket to hold a panel so that it can be set on the frame of a machine or moved about as the operator may need rather than it sitting on the bench. The idea is that it could sit on the top edge of the machine box but the display can't stick out much to the back into the gears or to the front off of the workspace. So in the sketch I would like to rotate the front of the bracket counter-clockwise a bit but it won't move and I don't see the constraint that is holding it. How does one identify what it is or push things with an angle kind of constraint (I don't see such a thing). This is the sketch:
https://cad.onshape.com/documents/c49343d69184c838eb540297/w/040bbfcfb1554607b063c5ff/e/5fea36f7ba59422624b01b3e
Thank you for any advise
Basically I drew the sketch and then started adding dimensions to it and it weirdly pushed the "front" down past the the base but I am failing to see how to find the constraint that is causing this.
No great panic about it now I started again and did it a bit differently and was successful but I would still like to understand how to diagnose this sort of thing.
Looks like the 125mm line was intended to stay horizontal but without a restraint to clarify, well......
https://learn.onshape.com/learn/course/introduction-to-part-design/part-studio-interface/introduction-to-parts?page=1
Is this what you were looking for ?
GIF will not post for some reason even
EDIT — I can now see the GIFs that I could not see before
Basically I drew the sketch and then started adding dimensions to it only trying to constrain the dimension that were important and it weirdly pushed the "front" down past the the base but I am failing to see how to find the constraint that is causing this.
@S1mon that looks neat, I'll have to play with that tool as I can see how it could be useful
So I did manage to create the part by starting again but I'll try this to see if I can fix the original
By chance, if you were looking for something like what is show in the 1st picture below,
Then there are 2 vertical constraints shown in the 2nd picture that need to be removed
and also a coincident constraint that is shown in the 3rd picture that needs to be removed
@NeilCooke
I still can't post a GIF
