I am having trouble using the animate feature for the mate in the third image. Please help!
adam_ingramadam_ingram Member Posts: 4 EDU
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,868
    You want to animate the screw? It would just be the same as the other screw in this assembly.
  • adam_ingramadam_ingram Member Posts: 4 EDU
    but to animate the screw with a slider action as well.  to truly make the screw follow the threads ( I know it needs the cylindrical mate) but also have it follow a slider mate pattern as well.  It won't allow me to make the screw action up and down following the thread pattern.
    Not sure what the issue is without looking but here is a simple example: https://cad.onshape.com/documents/462a2d3435d4455e8ea0c2a5/w/530dbd9c64e8cab867fc570e/e/8d6a32a95fca174fc1e99c94
    Just set the distance per rev = thread pitch. You can't pull the screw and expect it to spin, you have to rotate it.
